Hi all. I am in dire need of some help. Through our university, we are competing in the Baja SAE competition. It is a collegiate engineering design competition to design and manufacture an off road dune buddy.
To cut to the chase, we were donated a 2011 Hisun HS 700 UTV, and we are using suspension and drivetrain parts off of it in our design. I am in the process of ordering new parts, but I am coming to a standstill.
Does anyone have any experience ordering parts for these machine?
From what I have found online, these machine were sold by Tractor Supply, along with a few different brands that share the same parts (Supermach, Coleman, Massimo, etc.)
Any help is appreciated. Thanks in advance.
There are tons of parts on Amazon and eBay. Other than a proprietary part (such as some makes have hoods that open, some have doors) the basic mechanical parts crossover widely for different iterations. Such as Massimo, Bennche, Axis, Coleman, Cub Cadet, Vector etc. Sometimes Yamaha rhino parts work. It’s sometimes a crapshoot but doable. Check out some YT channels, they often leave links in the descriptions. Wish I had a better answer for you. Good luck
Pop Bob
    • By Marie
    • By Frank Mac67
      - NO CLICK - NO OTHER NOISE
      Can anyone help?
      Can anyone help with this?
