Stuck in LOW
By Gary Odom
By carl baney
By Bjabbarw
By Gary Gallo
Just wondering if anyone has had problems with bed warping coming from the heat from the muffler.. If I ride more than 5 minutes my bed starts warping from the heat.. Does anyone have any recommendations on what wrap or shield I can get to prevent this before my bed starts cracking or the warping becomes permanent.. I only have about 50hrs on the UTV.. Basspro said they haven’t had this problem from anyone else.. Hard to believe..
By Paul in Wisconsin
I called Cabela's to try and get the saw bar. They said they can't get one and the 800SX doesn't have one!!?? Then why is it listed in the service manual?? No answer from them.
