I have a 2009 Joyner T2 for sale.  1100 cc Turbo charged motor with five speed transmission. full cab with heater, up graded steering box, new himes joints, 2 inch lift with up graded shocks and travel limit straps, up graded induction system, remote oil filter station with two large filter which hold and extra gallon of oil, up graded rear diff, mud flares, up graded axels, up graded wheel bearings, extra set of 27 in tires, extra up graded diff as well as original shocks and axels. 12 inch wheel travel with 17 inches ground clearance. 6000 miles on unit. comes with 14 ft trailer with 3500 lb axel.   8500.00   This has been a great machine which I use for hunting only, never raced or hill climbed.  This machine has never been off it's wheels as in never been rolled or abused. You can contact me on this site or call 970-986-0268 as well as e-mail me at bugler [email protected].  I can send pictures if your interested.
    • By Frank in MI
      Thanks for accepting me!
    • By KimAC
      -Kim
    • By hisun junk
    • By NC4wd
    • By Poppateets
