2014 coleman 700 utv starts idles about 15 seconds then dies any thoughts would be appreciated
By Jr Perez
By Rainman
I want to put a charger/maintainer for my Coleman UT400 for the winter and need to know if it uses a 6v or 12v battery.
One search online showed a 6v, but another stated 12v..
I can look at the battery, but after taking the seat out you cannot see the top of the battery without also removing the top plate under the seat and at 8 degrees outside, I'd rather not be out there too long.
Can anyone verify what volt (6 or 12) the batter is?
Thanks in advance ...
By Alien10
