  • 4 months later...
Hey, Brandon!  I'm looking for a USFS approved add-on spark arrestor for my 2014 Renegade R2 1100cc.  Do you have them or do you know who carries them?
  • 2 months later...
silverbullet.
Our parts are always low we sell only the best parts original Chery.We do not have to be called we are always at low price. 5% every 100 dollars you save $5 dollars.All are parts come with a 1 year warrant which is important to give you piece of mine.All differentials we sell our taken apart and upgraded with 12.9 headwear.Tig the pins and set back lash.German wheel bearings no plastic only the best you can just look at them and all you see is quality they come apart so you can lube them.Our throttle cables and out clutch cables will have stainless steel cable so no more rust.Should last at least 2 years or more and we stand behind it.We have always had a 10% percent discount for UTV members for 6 years.The cables will be available in 1 to 2 months.
We have sold to many members over the years and having given them the 10%.discount.
     Google spark arrestor exhaust
    • By CYJSP2009
      Dear Joyner owners
      3. Cables,
      4. Brake parts
      5. Engine parts
      6. Other parts.
      Have a good weekend
      Casey /  Leaf Asia
      2023-11-17
    • By PossumTruck
      Greetings,
    • By JimWil
      Looking for a place/website to order a  replacement bench seat and a dump bed fender from.
      JimWil
    • By Kingfish
