Trooper 1100 fuel pressure
Jarrettj88
Ok thank you. Have another question you might could help me with. I bought a 25$ adjustable fuel pressure gauge to swap mine out with because it wouldn't hold but 20psi and wound send the rest to the tank. I put this new one on and it wouldn't really adjust or hold the same constant pressure it with between 60 or 80 then will just drop to 10 or 20. Would anything else cause this or just another bad regulator?
Sent from my VS880PP using Tapatalk
I have used Team Joyner and now Joyner USA so i have been selling parts for about 15 years.I have found that you can get a better price from [email protected]. Eric is a good guy and will almost always have a better price.Forget the 5% lower price.That just sales talk! Eric will give you the best price that what i have found.Are prices our vary good to and we only sell Chery Parts.We are working with China on some outer c/v joints.So you can replace just the outer joint.Not the Up grade kit.For some its going to work out better for a lot less money.They Up grade is good but if you don't want to invest 600 dollors
On a 3,500 Joyner 600.00 is a lot of money.The outer joint sell for 105.ea or a pair for 200.00
  • 2 months later...
Most of the times, the regulator was set up wrong. The lines should be on correct order. Mine regulator (ebay 20€) worked fine for 2 years.
fuel cell - line - t-adapter to fuel rail - regulator - line to fuel cell
Gesendet von meinem SM-G920F mit Tapatalk
    • By FGT
    • By Challenger750HP
      I have a 2017 Cub Cadet Challenger 750 and I have been watching videos on the top end rebuild of the same engine. So, I have one question about it and I’m not sure if someone could help or not. I’m having trouble getting mine to fire over. Could anyone explain how to set the timing on both the flywheel and the cam? I think I may be setting the cam in an incorrect direction. When I put my foot on the brake to start the engine turns over and I have spark and fuel but I cannot get it to fire. The timing chain was off at first and I reinstalled it and tightened it with the tensioner and everything looks good but I cannot figure out how to set the timing perfectly to make it start up. Do you have any suggestions? Or any thoughts on what’s stopping it from firing up? I appreciate all of your help in advance!!
    • By Butcher6868
      I have a Coleman ut400, when I use the winch to raise the plow the battery light comes on, once I let off the switch the light goes off. Does anyone know if that’s normal?
    • By rocket100
      Just got my new Renegade R2 delivered with 2.6 miles on it and changing all the fluids.  They must put everything including the oil filter with an impact.
      Last thing is taking the the skid plate off to change the transmission fluid.  Any suggestions??
    • By The Wanalds
      How to use the MODE and SET buttons on the display panel. What functions are controled.
