go back to the basics. check compression, check spark, remove injector and crank to see if fuel sprays. Sprays!, not drips or squirts like an old man.
I already suspect a plugged up injector. If so, you can try to clean it up, but they're not expensive. I would recommend also adding an inline filter.
Good luck. Keep us posted
Pop Bob
Man, I agree with Pop Bob that it is likely the injector.  Some Hisuns were manufactured and sold without an in line fuel filter.  There have been several videos on line of folks suffering from the resulting clogged or malfunctioning injectors.   They simply do not like anything in the fuel they are spraying.    Adding an in line fuel filter is easy, and an absolute must.
i dont know i was driving and it started losing power so i shut it off. then 10 min later started it went about 500 feet down road then it just died. the motor made no weird noises or anything like backfiring or clanking. The mechanic said it hit the valves.he said he tried resetting timing chain and while cranking it it jumped again.so waiting for parts to come in and get rebuilt at shop. the machine only has 300 hours on it.sucks i only put 30 miles on it after I bought it used
Unless you know the former owner, there is no telling what kind of life it had in its 300 hours.   Maybe you have already gone over the machine but check for signs of rough use. Do zerks and joints appear to have been maintained, brake pads, hidden areas packed with mud?  I know its a UTV but there may be signs of it being "abused" as opposed to just being "used".
Sorry you are having such issues.
    • By Ed Michael
      Subaru SxS.mp4
    • By Some random dude
      2015 Hisun 700 Utv
    • By Duane Baker
