Joyner trooper 1100cc
By Alien10
By Jacob E freeman
By Texjpr
2002 ranger 500 4x4 stopped running and wouldn't restart. Service manual wiring diagram helped identify the hub safety switch as the culprit. Using jumper wires to bypass switch allowed the engine to start and run normally. Inspection of switch showed melted epoxy and a strong smell of burnt electrical. Unable to find replacement part either used or new. Is there a work around other than jumper wiring?
By Oldman
Ive got an American Sportsworks BD-200. I can’t get the ignition switch to work, but if I cross the solenoid, it starts right up. Runs great. Can anyone send me a simple wiring diagram for a switch and where the 3 wires from the switch go! Any help is greatly appreciated!!! Thanks!
By htrotte
#1 While troubleshooting an issue with temp warning light I discovered another temp switch mounted in the pipe going to the head The two switches are literally 6 inches apart. Does anyone know what this third switch is used for? If i can figure out how I will post pictures.
Author #2 Finally got the pictures took. See the photo and tell me if you know what the switch on the right is.
It looks to be factory and I know the girl who bought it new and she didn't install it.
I can't find anything on it in any manual i have looked at. Any help would be appreciated.
