My trooper intermitts when it wants to start.. it will always start cold..but if you shut it off it might start again and it may not.. it won't fire..but it you wait 5-10 mins it will start up just fine again until you shut it off.. I can't figure it out soo it's been idel if a lot lately..
Sent from my iPhone using Tapatalk
Yes just don't fire.. wait a few minutes and it will start right up and run fine until u shut it off again .. I'm gonna try putting new plugs in it tomarrow
If that is the stock gauge, it probably isn't correct mine was showing 45 psi and when I put another one I had in the shop, it was more like 25 psi.
Go ahead and change your plugs (cheapest 1st) but I've never heard of plugs getting hot and not working.
Fuel pumps and ignition coils usually. Keep us informed on how the plug change goes.
So your fuel pressure is 45 or 25 psi... it is the fuel pressure...I watch my gauge.. when I shut it I watch it bleed back.. when it gets to just below 40 psi it will start
I took it down to 30 and it doesn't doesn't wanna run that low and still having to delayed start problem...my ejk fuel controller instructions says to run it at 53-55 psi...
Yes.. i also turned the fuel pressure down to about 50-52 psi.. it wasn't running rich.. air/fuel gauge is running at about 14-14.5 warm..I took it riding the other day for about 6-8 hours and i had to wait for it to start a few times that morning but after that it hasn't don't it anymore.. I don't know for sure but I think it's was because i had it very very rich before and now I got it running pretty go now..
  • 2 months later...
Start having the same problem again and when it does it.. it won't fire either...its was a loose ground problem on the transmission..its fine again .. for now..!!! Lol
Glad you figured it out. At the end of the season last year Mine was dieing on me when coming off throttle from time to time. Then it didn't want to start afterward. I found oil in the intake and on the intake sensors. Also found a suspect air leak in a cracked intake rubber plug.  Cleaned the sensors and filled the plug with rtv and is running great. Keep an eye on rubber parts. They are always cracking.
2scoops, from my experience, if you have oil in the intake, you may be having too much bypass around the rings, do you still have the oil/air separator mounted?  FYI My '15 doesn't even have one.
    • By Nutcase
    • By Will Sutton
    • By fishhouse3
      This machine is ready to go and needs nothing - just hop in and hit the trails!  I have over $20k invested in this machine. Priced VERY fair to sell quick at less than half that!!!
