Throttle Cables
By Kingfish
By mac66
By sxr951
By JSmojo
I've been looking at various types of UTVs in the 400-700cc range. It seems that Massimo has a really good price point but I don't know much about their reliability and availability of parts. Been looking specifically at their T-Boss 550. I've heard the parts might be an issue because the network is smaller, but couldn't find much info from owners.
Here are a few specific questions about them
1. In your opinion, are the reliable? Specifically, have you hand any parts break that in your mind shouldn't have?
2. If you had one and got rid of it, what was the reason?
3. If you don't recommend Massimo, what would you recommend (even if it costs a little more)?
4. How easy is it to find a place to service them? How easy is it to get parts if you want to service it yourself?
If you have any other advice, I would appreciate it. I'm also looking at the Hisun Sector 550.
