Joyner trooper rev limiter
Picked up an essentially new 2022 UT400 with 9 miles on it. Decided to change the oil because it's probably never been done. Pulled the dipstick and noticed it was overfull then went and pulled the drain plug and took off the filter and it was like brown water running out. What should I start checking?
By SouthernGypsy
By JOSEPH LAMAR
By rev6engines
Call or Text:
801) 489-8697
Email at:
[email protected]
Happy riding!!! 🤘
By Will Sutton
