Joyner 1600 - 5th gear + speed up options
Yoshio
    • By redneckred
      Can anyone tell me how to get the engine codes to display on a 2012 Bennche Bighorn 700X?  I played with the gauges once and lucked up on this but can't remember what I did.  Will the codes automatically display if there is a code or do you have to cycle through the display?
    • By Chas
      When traveling in the 40 mph range and throttle is released machine starts surging instead of a gradual slow down any help would be appreciated as dealer is clueless
    • By aefron88
    • By Jon V
