silverbullet
We have found it to be louse gauges.When we test oil presser we put a new new gauge and we have about 12lbs. of pressure at ideal.and usual 45 at speed witch is good.
So if you want the true pressure than you replace gauges.Same with the temp gauge.Just junkie gauges you can buy auto meter gauges for the same price.All you have to do is run a new wire or some times use the old wire from the original system.
  • 2 months later...
    • By Jim Kessell
      Hi All
      Jim
    • By bms stallion owner
    • By SpaceGhost
