Hello people. Just bought a new to me 2011 Polaris Ranger 500 efi side by side. Don't know to much about side by sides so I guess I will learn as I go. Live in  Nova Scotia and we still have snow here. Starting to warm up a little now so now we have snow and mud. Glad to be a member. Have a good one.
    • By Frank in MI
      Thanks for accepting me!
    • By Poppateets
    • By NC4wd
    • By rev6engines
      Call or Text:
      801) 489-8697
      Email at:
      [email protected]
      Happy riding!!! 🤘
    • By Greg Kilgore
      Plumbing parts list.
      2 1" x 3/4" x 1" PEX Tee
      1 3/4" PEX ball valve
      1 1" PEX ball valve
      Wide view of the plumbing.
      Kilgore.
