ELEVATOR 2000E REPAIR SHOP GRADE MOTORCYCLE LIFT TABLE
2 year warranty
48" Maximum Height
8" Collapsed Height
Includes 4 equal piece (quarters) side extension kit that extends the lift to 56", plus 2 loading ramps. Optional wider Side Ext Kit 68" width.
Electric over hydraulic power 110 volt, 2000 lb capacity
Fully adjustable wheel chock with a quick lock
2 Button Electric control and Cord
Heavy duty track and bearings for smooth operation
4 panel (quarters) quick mount side extension kit with ramps
Base frame pre-drilled for wheel kit
Multiposition safety lock system
Optional 2 year extra extended warranty available
Call 603-234-2612 or Visit:
https://www.nhproequip.com/elevator-2000e-motorcycle-lift
    • By Robbie Wyre
    • By Brett
    • By Jerrys500
      Thanks Jerr
