Trooper tranny swap..??
Tobie1987
silverbullet
The the CVT system in the ground ponder never worked.They would burn out the belts all the time. Chery makes one with a chain but they will not fit.I tried to buy one but vendor said it would not fit the SQR472 engine.This belt system can not take the torque of the 4 cylinder motor.The V twin motor doesn't have much torque i would think and the weight is much less.Take this information as my thoughts only.Outer C/V joints for 800 M/V 1100cc Viper are in stock now.Coming soon 650 Spider and Viper Trooper & Renegade.
  • 4 weeks later...
    • By lmarkie
      Any thoughts?
    • By Jhud
      In the market for side by side. Narrowed it down between the pioneer 1000 or defender Hd9. Looking for pros and cons of both. Any info would be helpful in my selection process. Noise, speed, reliability, ride, all of it.
    • By Reuben
      My 2015 450i UCV dies when I take my foot off the accelerator when traveling at a slow speed. Can I adjust something to make this issue stop?
    • By Mark T
    • By AlphaSerenity
      Hello,
