Hi I am from North Dakota and have a Trooper2 and a BMS 1100cc dune buggy. Driving them has got to be the most fun you can legally have.
Just got the BMS in June and the Trooper in August and cant get enough time in them. I only have 750 miles on the buggy and 350 0n the Trooper. Cant wait to get some snow to see how the Trooper will do. Possible this weekend could be 10-12" although it wont stay long yet.
    • By hisun junk
    • By Jacob E freeman
    • By Gerald Mohs
    • By mark walkom
    • By Gary T
