silverbullet
I have to say i have changed 100 of c/v axles.My C/V  manufacture said not to tighten more than 60 to 70 pounds of torque.When we are tighten the nut we are putting a lot of stress on the outer joint.The cotter pin holds the nut in place use stainless steel cotter pin.It is pulling the joint apart and when you hit some thing it brakes.Now if you are running around with a torn boot than that is another reason.
  • 1 year later...
    • By SpaceGhost
    • By Kingfish
    • By mac66
      Apparently, these are Hisun or at least they use Hisun engines. I can't find much info on them online yet.  Ran across a used one with just 100 miles on it as a very reasonable price.  Just curious.
    • By sxr951
      corrosion had its oring neck area  jammed in.. and besides that had corrosion in the starter just shorted when ran direct jumper cable to the starter post power to it
