New member here
By Kevin Ullman
By Kevin Ullman
By davebuckholts
I just picked this UTV up off of Marketplace. It needs batteries.
I am installing a single 48v lithium battery.
The on board charger, a NOCO Genius GX 4820, has a lithium mode.
Has anyone here used this charger on new lithium batteries? I want to be certain of the compatibility before hooking the charger to this expensive battery. **
I got in touch with NOCO and they told me the charger is fine to use on a new LiFePo battery.
Nice charger. Many modes. New ones are running about $550.
By Matthew Smith
2013 Bennche Bighorn 700 EFI
