Finding Gas Shocks for front Struts impossible??????
By CSM_Retired
By Grant
By Matthew Smith
2013 Bennche Bighorn 700 EFI
By Jim Kessell
Hi All
2010 653cc
Need any information on a Subaru Robins EH65 engine. Particularly the carb vacuum line to the bottom of the carb. I think it’s disconnected internally in the engine.
Thanks Jim
By dman66
