Coleman UT400; Hisun HS400
John Gubancsik
I have almost the same issue as John.    Parked my 2022 Coleman 400, (seatbelts crossed and hooked up continuously) then it refused to start until pressing the gas pedal.  Stalls when I let up on the gas.  Checked connections on seat belts( where is the seat belt limiter?), removed all connectors and sprayed with electrical cleaner.  Changed MAF sensor, checked fuel flow (new fuel filter), good spark checked with inline tester (new spark plug).
As I understand it, the MAF is also a temp sensor that determines if it’s a cold or hot start and schedules fuel accordingly?  About a month ago on first start of the day it cranked but no start.  Pulled MAF connector , sprayed and it started right up.  When it happened again 2 days ago I ordered a new sensor to help eliminate possibilities after cleaning didn’t work.
Does the ECM fail on these at times?  Ive had to replace the water temp fan relay and I’m just wondering if the sensors and electrical control are the primary fail points of the 400?
If someone with experience on this rascal could elaborate it would be greatly appreciated!
 John I apologize, not trying to hijack your thread it just sounds like a similar problem.
Scott
Guys, I think you’re sniffing up the wrong tree with the seat belt limiter. My Vector 500 does this intermittently. While you can start it and keep it running with a little throttle, it will drive fine at any speed as long as you don’t let it idle. If the limiter was working it would not drive. I can’t tell you what it is,yet, but I don’t think it’s that. Mine always resolves itself over a couple stop/start cycles. I’m purchasing a code reader. I’ll let you know if I find anything.
Pop Bob
    • By Browner010
    • By KidColeman
      Just picked  up a 2020 UT400 that my 80 year old father will be driving around the farm.  We purchased the machine with a few "issues" and they lowered the price accordingly.  Small stuff like passenger size mirror and back reflector was torn off by a Tractor supply employee, which we will order replacements for.  Also after further inspection, whoever assembled it did not put a few bolts in the rollcage and aren't in the glovebox, so will be having to order those also.
      Anyway, there are two initial things on the UT400 I'm not sure what they are or for.  The first, there is a square white electrical connector with about 8 pins hanging form under the middle of the back bed - I don't see another one to match up or plug into it, so wondering if this is pre installed optional connection for like towing around a sprayer?  Anyone know what this is?  Also, there is a 10 inch black rubber hose that is zip tied to the back A frame on the passenger side.  I watched the assembly video and it doesn't mention one, so don't know what this hose is for - anyone know?
      Also, has anyone come up with a "fix" or work around for having to have the seatbelts plugged in or even in place?  We aren't planning on using them and are figuring just plugging them in and wedging them behind the seats - didn't know if there is a way to just disconnect the "over 10mph gas starving" safety sensor.
      Looking forward to seeing how this machine does for my father.   I'm thinking about installing a suicide knob on it for easier turning for him, as it's a little stiff (compared to our Kawasaki Mule).  Maybe with use it will loosen up some?
    • Sell your car with CarBrain
    • By kadams428
      Recently my four wheeler has had an issue of being set in gear and it begins riding on its own (up to 3-4MPH). It also is having difficulty shifting into different gears after riding in one gear (i.e. going from reverse to high gear). It will shift perfectly fine when shut off, but consistently has both issues stated above.
      Previous research has shown me that it could be an issue with belt tension/deflection, however I have been unable to figure out how to do that with these machines. I've seen some clutches have a jam nut and all that is needed is a wrench and an Allen key to make adjustments, but I haven't seen/found that on the 600 clutches. Has anyone done this in the past or have knowledge of how to accomplish this?
