Electrical Gremlins (Wench, Lights and 4x4)
By downseast
Hi everyone
By Jim Kessell
2005 American Landmaster
EH65 Subaru Robins
By Greg Kilgore
By SayHiToRambo
08 trooper 1100
thanks!
By Buck
My father-in-laws 750 hisun will not change gears unless he completely turns the motor off then shifts. I thought it might be a brake problem but he thought clutch. He took it to a jackleg down the road and he basically charged him $300 and did not fix a thing. Any ideas would be useful because he really can’t afford throwing money at it.
