Tires for 22/11-8”
By mhill
Any thoughts? Suggestions?
Thanks so much
By Jim Kessell
Hi All
2010 653cc
Need any information on a Subaru Robins EH65 engine. Particularly the carb vacuum line to the bottom of the carb. I think it’s disconnected internally in the engine.
Thanks Jim
By Alien10
