Hey guys it's been a fun and interesting few years! I appreciate all the help and hope I helped on some of the issues we have had.. But the time has come to let the T2 go..
The man I sold it too is an awesome guy from Louisiana...
His name is Earl. Couldn't ask for a better bunch of people got to meet his whole family....
Anyways it would be great if he needs anything in the future if yins could treat him like you did me...Fantasic like family! I know 99 percent of yins will.
I sure gonna miss you all. I'll stay a member on here and will watch for emails and still will help out if I can... Best Wishs!
Dan
    • By Dennis
    • By Marie
    • By Frank Mac67
      - NO CLICK - NO OTHER NOISE
      Can anyone help?
      Can anyone help with this?
    • By John Doe
      Hello,
