...TRUMP! Every Trump hater needs to watch this. Funny, Conservatives put up with 8 years of Poobama, and we never set buldings on fire, or killed people, Libtards don't get their way for 6 months and they are tearing the country apart!
YUP 4 sure.  Travis you have smart people, just more of them has to vote every election and you'll never see the democrats again!
Trump bashing is done because foreign countries are paying them to. Corruption, kickbacks is at the core of their criminal activities. Look how much the Clinton foundation had to give back.
Trump can't be bought so he's not working for foreign interests like Hillary was and is. There are always foreigners trying to destroy the west, this will never stop until be bury all of those muzzies.
    • By FGT
      QUESTION: How to wire the C/B into this current dual battery set up.
      EXISTING SITUATION: MAIN Battery is OEM and feeds OEM circuits. Added an AUX Battery in the OEM dual battery location. Connected the AUX - terminal to the MAIN - terminal. Connected the 100A Accessory Fuse Block power cable to the AUX + terminal. Installed a smart isolator between AUX and MAIN batteries where a cable from AUX + goes to the isolator and a cable from isolator to MAIN battery + terminal. Installed separate QD battery tender cables to both AUX and MAIN batteries + and -. The dual battery system appears to work as intended. For this Phase 1 improvement, to avoid having to constantly pull the leads on the AUX + battery post off and put on, for testing or maintenance of Accessory circuits, I wanted a more convenient and safer way to open the circuit from the AUX battery + terminal the Accessory Fuse Block. I called an off road dealership and was told to install a much larger capacity circuit breaker than the 100A rated Fuse Block and was recommended to get a 250A C/B like the one in the pic, which I did. I was told the reason for the C/B high amp rating was two-fold (a) to trip in the event of a battery short circuit and (b) to be able to conveniently open the C/B to kill power to the Accessory Fuse Block without removing leads from the AUX + terminal. The 250A C/B has two posts labelled "BAT LOAD" and "BAT LINE". There are currently three connections to the AUX + post: (1) Accessory Fuse Block power cable, (2) cable to Isolator AUX in terminal, (3) cable from AUX battery charger.
    • By Stan Morton
      My 2018 XG-850-SL starter died yesterday. The old part number from Kubota is E7153-11732 which has been superceed by part # EG881-63010. I am looking for an aftermarket starter because the Kubota retail price for the starter starts at $550 and upwards toward $850.  If anyone has gone down this road before and has found an aftermarket starter ~ please share with me. We own a ranch and this thing is used every single day and is sorely missed when it is down for maintenance.  Kind Regards, ~ Stan
    • By Mark T
      MY 400 is gutless. I would like to know if I can upgrade to a larger engine ?
    • By Rizzguy
      Don’t waste your time everybody with rpm motorsports, Omaha. They are people that don’t even work on sxs’s. Trying to tell you how to install things.
      Completely uneducated guy tried to tell me I did not install a mid pipe correctly when it won’t install correctly; that was the reason for the video and the complaint that I called him about.
      This mid pipe has a 1 inch gap at the rear, and the only way to close it up is with a longer bolt, and to stretch the flex at the Exhaust
      After one ride, the rear bolts have disappeared, because how much tension there is on the flex
      And the bolts does not line up at the flange
      Have a video before and after. And they are telling me that it’s my fault because it does not fit
      wtf.!
      What kind of idiotic people are even answering the phones these days.?
      This guy has probably only read a book and never even driven a motorcycle in his life
      Don’t waste your time with this bullshit products
