Do Adults Use the Hisun 250's?
By Anthony Vigil
Can anyone tell me how they grease the drivelines ? Can’t grease the u joints. Do you need to take the driveline off ?
And are they easy to take off?
By djl
Hi All. The splines are pretty well worn where the rear driveshaft fits into the adapter (boss?) on the rear of the engine. I have a new driveshaft / adapter / seal to install but am having difficulty loosening the nut holding the adapter onto the transmission output shaft. I purchased a chain-type vice grip tool thinking that I could get it around the adapter to prevent it from turning but have not had any luck getting it in there yet (very tight space). What approaches have you used that have worked? Thanks!
By Justin Felker
Had some issues where I was losing power on my Hisun. Got it back to my shop and it wouldn't start. Drained the fuel, replaced the plug, injector and TPS, cleaned the air filter. It will start without the air intake attached to the engine but once I put it back on, it will die. Any ideas on what else I need to do?
By JimS409
I picked up this Hisun 700cc for a good deal. no crank no start unit 1900 miles on it. Put a new battery and starter solenoid fired right up but sounded rough some kind of rattle/clunk noise. Does anyone know what this noise could be? Couldn't get a better video of it running as i don't want to risk doing more damage. Drained the oil it looks good no metal in it.
445374820_7315077208620291_6073155782020130975_n.mp4
