Cinda, it was Side X Side magazine and this is the link to the UTV Shoot-out http://www.nxtbook.com/nxtbooks/pgi/sidexsideaction_200804/
This link shows all the digital editions including Vol. 3/ issue#1 which has a good article on the Trooper. http://www.sidexsideaction.com/digitaleditions/
Finally this is a link to an article about Joyner at Country thunder 08. http://www.thunderinc.com/sidexsideactionmagazine_sept08.pdf
    • By Browner010
    • By Red Good
      Serial # a8mv86futja001002 , no search engine will give me a model , it has a 471 engine . Is massimo always hard to get hold of ? No answer to emails or phone calls ?
    • By diamondjfarm
      Thanks.
    • By The Road Hound
      Hi,
      New to the forum.
      Came here looking for some experienced UTV users who can enlighten me about which brand should I pick for my very first UTV or SXS.
      I'm between 3 brands and 3 models:
      *Kawasaki MULE PRO-FXR   1000.
      *Yamaha wolverine rmax2.
      *Can am Commander XTP.
      The use I'm willing to give it is mostly to go to the range with my wife, load steel targets and all our shooting gear, we shoot a lot, rifles, Shotguns and Handguns for practice, training and competition. (Range is about 10 miles from home)
