Hisun 500cc NO SPARK
By Croppy38
I own a 2017 Challenger 750 and had the key way snap at the flywheel. It was removed and cleaned up and then the flywheel was put back on with a new keyway. It snapped a second time so the flywheel and keyway both were replaced. They both seem to fit nice and tight. Put it all back together and it snapped again. I have no idea why it is doing this.
By Woody77
UTV MASSIMOREPLACED STATOR WANT start replaced rectifier still want start stator ohms out 5 ohms each leg what could be wrong at this point
By Grizz
hello grizz again I keep blowing this fuse left side on bottom it’s a 15 amp I have checked all the wires can’t find anything bare or broken it is a 2021 axis 700 I put a 20 amp in so I could pull out of shop to take pictures. Does anyone have any suggestions. Thanks.
By goindeep
Well now i could use a lil help... i have a trooper in my shop now that has wiring issues... this poor guy paid another shop $1000 to re wire the body control harness, and boy oh boy did they chop it up!!! I am Buillding a new harness from scratch... what i need is a diagram that tells me what each fuse and relay control on the Engine fuse/relay block.. any help is greatly appreciated!!
Josh
No Limitz
By Hector
Hello all,
I got a 2009 T2 and found the wiring on the fuse box that holds the fuel pump and ecu power had a short and was not wired correctly. I wanted to see if anyone could provide a picture of the back of theirs so i can see how it is wired
thank you
