By Jim Kessell
Hi All
2010 653cc
Need any information on a Subaru Robins EH65 engine. Particularly the carb vacuum line to the bottom of the carb. I think it’s disconnected internally in the engine.
Thanks Jim
By Venom
I picked up an old beat up 2010 American Sportworks Bull Dog 300 BD300. I would like to restore her... Does anyone know a good source for parts other than the OEM? I find $130 for brake pads is kind of unreasonable... I also need a steering rack and other things... I took apart the steering rack and it needs a new bearing and oil seal... Of course the OEM only sells the complete rack for over $200.. I found the correct bearing for $6.00. I am having trouble finding the correct oil seal..
Anyone that has info on one of these machines, please chime in... I am used to the ease of finding info on Polaris, Honda, Can Am, Kawasaki, etc....., Info and parts on these seems to be scarce.. Some of the parts on it look like Golf Cart parts as well as some look like Go Kart parts..
By Buddee
2010 Hisun 500 - Carbed'. She sat for about 3 weeks since last use. Couldn't get it started.... has spark but plug was not wet. Bought new plug, cleaned the carb, confirmed fuel pump (pulse type) is working. Still nothing. Put gas in the plug hole.... started right up and idled as normal and drove perfect. Used it for the rest of the day without issue. Tried to start again next morning.... same problem. Poured gas in plug hole again.... started up and best kind again.
Anyone have any insight to what's going on?
By vachi
hi everyone i have this 2021 Hisun forge 250 that won't start. no spark no fuel. when i turn the key on i dont hear the relays click or fuel pump come on. it does have power but the relay doesnt ground the pump or the ignition coil. dont know if there are any safety switches on this model or not. it does crank and all the accessories work. i hot wired the pump and it does work. i found a wiring diagram but it's very hard to figure out and was hoping someone has seen this before. all fuses are good. thanks in advance.
By boydog40
thanks guys
