EH65 spitting fuel from breather hose into air filter.
Go to solution Solved by Jim Kessell,
  • 4 weeks later...
Just like an old car or truck PCV valve.
PCV = Positive Crankcase Ventilation
Basically any gasses that blow-by the piston rings into the crank case need a place to go. So the PCV valve (one-way check valve) let the gasses out but doesn't allow any in. Usually a hose runs from PCV valve to breather and sent back into combustion chamber.
Since the gasses are in the crankcase some oil may be pulled up as well.
Or it could be something else. Just a thought. Home this helps and good luck with the repair.
Kilgore.
On 10/26/2024 at 1:51 PM, Jim Kessell said:
I apologize to all who I left scratching their heads about my last post !!
Turns out to be fuel diluted oil coming from the breather.  I’ll be taking the carburetor off AGAIN !!!
Jim,
Have you checked oil level in engine? Does it smell like gas? If overful it could be sucked by the breather back to carb.
WB
I was hoping you would respond.
It was definitely gas infused and slightly over full. Took the carb off and changed the float and needle valve.  Reworked the fuel solenoid.  I have it running pretty well now but was having the issue with the blow back.
  • 4 weeks later...
WB
Merry Christmas to you and yours !
WX is keeping me in the house for now.  One thing that was obvious from the start is the exhaust has to be reconfigured to fit the machine. Search around the local marketplaces.
I found my Predator on offer up for $100 bucks brand new.
Hi Jim,
Merry Christmas to you and yours also,
I saw somewhere you can order flange with stub out for that engine. You might weld flex hose onto stub and run it wherever you have to. If i see it again i'll post it to you. Wow, where did you see that engine for $100. Might be a scam. check close.
  • 5 weeks later...
Is there any way that you could post close up pictures of where the springs would go and the rods on this eh65 engine
I took pictures but cant find them and I can get it to run but its not right imo
    • By weasel
    • By Chucky 1
    • By Buck
      My father-in-laws 750 hisun will not change gears unless he completely turns the motor off then shifts.  I thought it might be a brake problem but he thought clutch.  He took it to a jackleg down the road and he basically charged him $300 and did not fix a thing.  Any ideas would be useful because he really can’t afford throwing money at it.
    • By Jim Kessell
      Hi All
      2010 653cc
      Need any information on a Subaru Robins EH65 engine. Particularly the carb vacuum line to the bottom of the carb. I think it’s disconnected internally in the engine.
      Thanks Jim
    • By BMurph
