Can't upload avatar in .jpg format
By NicholasNWM09
Hello Everyone,
COOL NEW Product Alert!
A company called NEW Wire Marine or NEW Wire has Badass custom panels for UTV, Buggy/Hunting trucks. From Fully wired switch panels with laser etched rockers with backlights in 5 different colors, to just parts like voltmeters, phone, USB and 12 v chargers. Rockers can be printed, or custom laser etched rockers and they even have sleek labeled pushbuttons. They are a first-class company with a great knowledgeable staff and outstanding customer service. Switches are based on 12v or 24v circuits and they also have marine grade wire and connectors, which is perfect for waterproofing your system!
Go check them out!
Check out the websites : https://newwiremarine.com/ and https://rockerswitchpros.com
By NicholasNWM09
Hello Everyone, COOL NEW Product Alert! A company called NEW Wire Marine or NEW Wire has Badass custom panels for UTV, Buggy/Hunting trucks. From Fully wired switch panels with laser etched rockers with backlights in 5 different colors, to just parts like voltmeters, phone, USB and 12 v chargers. Rockers can be printed, or custom laser etched rockers and they even have sleek labeled pushbuttons. They are a first-class company with a great knowledgeable staff and outstanding customer service. Switches are based on 12v or 24v circuits and they also have marine grade wire and connectors, which is perfect for waterproofing your system! Go check them out!!!Honda - xxxx - UTV Pioneer - xx'.pdf
By Elk Hunter
I have Error Codes P0031, P0562 and P0616 My Tracker will not Start i turn the key and nothing at all it has a brand new Battery. Please help me fix this problem.
By Grumpman
I am a New Side by Side Owner, First one , and I am 71 years Old.
I purchased a slightly used ( 10 hrs on it) 2020 Rural King Performance 500 (Hisun)
My question is about the front lights. when I turn the Turn signal multi function light switch to what I assume to be parking lights, only the tail lights come on. The two amber bulbs next to the headlights do not light.
They only light up when I use the Turn signals or 4 way flashers. Is this normal?
I took a look under the hood and those lights only have 2 wires going to them, one is B+ the other is a ground, so I assume it is normal.
anyone else have one of these that could enlighten me? The Owners manual is not that informative..... doesn't even show the multi function Turn signal switch.
Thanks in advance
