  On 7/26/2017 at 2:47 AM, Travis said:
Should i use Brandname 10w40 or should i go with Kawachem. "kawasaki" oils?
Expand
Most UTVs/ATVs need to have additives in the oil so putting regular branded automotive motor oil isn't usually recommended. For years I have always used Valvoline 4 stroke ATV oil but any of the ATV type oils are usually sufficient unless a manufacturer recommends otherwise. 😁
silverbullert
Remove the oil filler cap, fill oil (SAE 10W/30-50) about 3.86 liters to the engine.This is what oil joyner recomends if engine is broken in than you can go synthetic or a good quality oil.We use the castor oil is a good quality oil.Try to get a Wix oil filter they make a good quality filter.Oil  10  w 30.
Thank You
  On 7/26/2017 at 3:10 AM, Alex said:
Most UTVs/ATVs need to have additives in the oil so putting regular branded automotive motor oil isn't usually recommended. For years I have always used Valvoline 4 stroke ATV oil but any of the ATV type oils are usually sufficient unless a manufacturer recommends otherwise. 1f601.png
Expand
All it says in my manual is use 10W30 or 10w40 oil... I don't know why, but i have a suspicion about UTV company oils, Like Kawachem, Yamalube etc.... I don't why but i do. I think I'll try the valvoline 4 stroke.
Thanks @Alex
Posted (edited)
Plus, Kawasaki  or at least on Amazon, wants $13 for a quart bottle!
Walmart has it for 4.00 a bottle, but its says ATV oil, but im sure as long as its 4 cycle its good.
And can you or anyone explain to me the difference between 4 cycle and 2 cycle motor oil?
Edited by Travis
Adding
When I bought Kawasaki Dirt bikes (100's); the dealer told me to use  Castrol 10W30 only (with filter). According  to him anything that runs high RPM's needs a quality oil like Castrol. He said that most other oils had a paraffin base; and Castrol did not  Not knowing; I followed his advice. Now everything I have uses the Castrol. O'Riley runs it on sale always; and I use their Microgard Filter. The specs are the same as Wix. A 5 quart oil change and two filters does Mule and the Cub Cadet
    • By TjB
    • By rsar
    • By Justine
    • By Travis
      View File Kawasaki Mule 550,520,500 Complete service manual
      This is a complete service manual for the Kawasaki Mule 500,520 and 550 models.
      Topics  covered include Brakes, Steering, Electrical system, suspension and fuel system. As well as engine repair procedures and Transmission/Final Drive procedures.
      If you need more information about the engine this manual linked below is chock full of information.
      Thanks goes to @cliffyk for getting these files all  into one PDF format for uploading.
      Submitter Travis Submitted 04/18/2021 Category Kawasaki
