30 inch tires on a trooper
Ya it's the same.. wanting to go to 30s to get more ground clearance and alittle taller 1st gear.. as of now with my turbo and 26s.1st gear is way to slow and 2nd is way to fast climbing hills..I got more then enough motor now.!!! Lol
Sent from my iPhone using Tapatalk
Got some 31 10.50 15 all terrain for now.. there in Honda Accord 15 inch wheels..gonna cut them soon... there about 50-70% tread..I haven't had it on the trail yet but down the road and back and it doesn't seem o have much loss in power with my turbo and msd coil..
Tires & rims look good, but it makes the Trooper look shorter, sort of, what's with the extra shock  on the swing arm?
If you take a Dremel tool and cut all the way around glove compartment detent, then add some walls so the bottom is as far down as possible and a lid, it makes for a nice usable glove box. I'll get  photo for you.
Jeff
PS read the pinned posts, Parts, Pieces, and Information for our Troopers & Joyners, it has the information
about the lug pattern, 4x115, and a lot more valuable stuff and it was mostly written by 2008 Trooper owners, including me.
  • 2 months later...
    • By Jon V
    • By Buck
      My father-in-law has a Hisun 750.  It has started to not change gears while running.  He can turn it off, change gears, then restart and it will change.  I thought it might have something to do with the brake but can’t find any info.  Thanks in advance for any info.
    • By Bartender
      Hey Yall,
      I have a 2011 cub cadet UTV that runs rough at higher speeds (sputters) . I changed plugs and replaced the gas with new . Does anyone have any idea thinking fuel filter or pump ?
    • By Richard shepard
      I have a 2021 colman 400utv engine will start and idle, as soon as you hit throttle to move engine dies and will only start when you throttle it, let off throttle it dies, I replaced the injector and plug still the same, anyone have any other ideas
    • By Kingfish
      I've had a battery failure and need one replacement.  The local distributor told me it might take up to four weeks to get one.  I'd like to order one in sooner than that if possible.  Any help would be appreciated.
