30 inch tires on a trooper
Ya it's the same.. wanting to go to 30s to get more ground clearance and alittle taller 1st gear.. as of now with my turbo and 26s.1st gear is way to slow and 2nd is way to fast climbing hills..I got more then enough motor now.!!! Lol
Sent from my iPhone using Tapatalk
Got some 31 10.50 15 all terrain for now.. there in Honda Accord 15 inch wheels..gonna cut them soon... there about 50-70% tread..I haven't had it on the trail yet but down the road and back and it doesn't seem o have much loss in power with my turbo and msd coil..
Tires & rims look good, but it makes the Trooper look shorter, sort of, what's with the extra shock  on the swing arm?
If you take a Dremel tool and cut all the way around glove compartment detent, then add some walls so the bottom is as far down as possible and a lid, it makes for a nice usable glove box. I'll get  photo for you.
Jeff
PS read the pinned posts, Parts, Pieces, and Information for our Troopers & Joyners, it has the information
about the lug pattern, 4x115, and a lot more valuable stuff and it was mostly written by 2008 Trooper owners, including me.
  • 2 months later...
    • By Hutch
      Okay everyone, need some help here. I got my 2014 Bennche Bighorn 700 from my father inlaw. He has had it since new and as far as I know never had any problems with it until recently. It began with it being hard to start and having to give it some throttle for it to start up. Then it wouldn't stay running once it did start. If you go to start it, it will fire right off and only run for a split second and then die. If you give it some throttle it will start and stay running as long as your foot is on the pedal. While it's running its pretty rough and backfires. Here is a list of everything I've done so far. Initially I checked compression and it was low. I changed the cylinder, piston and rings. Took the head apart cleaned and laped the valves. Checked timing a few times. Adjusted the valves. New spark plug. Checked the air filter, it was fine. New battery. Changed the fuel pump because of a broken fitting. Changed the fuel filter, lines and fuel injector. Dumped the old fuel and put new in. Changed the air idle control, TPS, MAP sensor, Voltage Regulator, ECU and harness. I was getting codes 31, 107, 113 and 122 on the display. Once I changed the ECU no more codes have been displayed but still have the same issues. All fuses look good and as far as I can tell Grounds are good unless there are some I can't find. I'm at a loss here. Not really sure where to go. Compression was better after everything I did but I don't remember the numbers. I'll have to check it again if someone thinks that could be the issue. Any help would be greatly appreciated!
    • By Jon V
    • By Buck
      My father-in-law has a Hisun 750.  It has started to not change gears while running.  He can turn it off, change gears, then restart and it will change.  I thought it might have something to do with the brake but can’t find any info.  Thanks in advance for any info.
    • By Bartender
      Hey Yall,
      I have a 2011 cub cadet UTV that runs rough at higher speeds (sputters) . I changed plugs and replaced the gas with new . Does anyone have any idea thinking fuel filter or pump ?
    • By Richard shepard
      I have a 2021 colman 400utv engine will start and idle, as soon as you hit throttle to move engine dies and will only start when you throttle it, let off throttle it dies, I replaced the injector and plug still the same, anyone have any other ideas
