By nods
Less than 40 miles can barely start. Dealer is working with Hisun on a number of other issues on this UTV. Can not get clear info on the meaning of these E codes this is getting. Anybody have some clear info for me?
By JoeK
I have a 2009 Hisun 800 Strike (Coleman) with crankcase speed sensor problems. Startup runs great for a while till it heats up. Than the rpm will increase slightly above 2.0 at idle and will not shift into gear because of the high idle. It will start to run rough and have no power like a timing belt jumped a tooth or like the motor is starving for air and just stop running??? Let it cool down and it will start normal but repeat the same symptoms again. Replace the crank sensor several times but it was only a temporary fix. Need help Thanks!!!
By Sma
Got a 2018 textron , looks like the head gasket is blown , been doing research and can't seem to find any (out of stock) or back ordered .
is it possible that I have to change the complete engine ??
can someone help me out Cheers
By Don W
Changing head and head base gasket, rear cyl. Can anyone help with head bolt torque? Thanks!
