Added a Website Help Forum
By camojay
1400 miles on it
20240817_133539_1.mp4
By diamondjfarm
Thanks.
By Alien10
I added lights to the Coleman Outfitter 550 last fall. I bought lights on line from Nilight, a 300 W 12" light bar mounted forward and 2 square 4" floods for the rear. Those are mounted on the roof corners facing rear and downward just beyond the tailgate. Nilights seem to be of high quality, as I've had them on my garden tractor for 5 years and still flood the way ahead with great light.
Both the front and rear lights provide amazing illumination making the OEM headlamps look like parking lights. Made a connector for the front bar that plugs into existing headlamp switch so it is just part of that circuit controlled by the headlamp switch. Rear work lamps were wired in using a rocker switch installed in the dash. Backed up to the garden with the work lights and was able to harvest some tomatoes well past sunset.
What have you used if anything for auxiliary lighting on your UTV?
By sxr951
2015 massimo 700.. need cylinder bolt! it some special cut from factory,, its a 125 thread but its like between 8 and 10 mm dont know where to find any ideas? thx
By BernieG
The second item is this vacuum valve looking thing. Again only one line is still attached. What is it's function and what other lines should be connected to it?
Any help the community could provide would be greatly appreciated. This UTV belongs to a friend, and I am trying to help him get it running correctly for his kids.
