Camshaft timing mark
By tipoblanco
Just purchased the Bighorn 550 explorer,after the breakin period what engine oil and diff fluid are you using?ive read about using a motorcycle engine oil or just a 10w40 blend?and differentials,states a 80/90 gl5,is there something preferred over another?is there a better spark plug than the K6RTC? just want to start out doing it correctly,im a true believer in proper maintenance,thanks for any contribution
By Wesley
I have a 2022 500 Hisun product, I have had them in the past. I change my oil myself and trying to drain through the hole where I remove the plug is a mess. How does everyone keep the belly pan clean during the oil and filter service?
Wes Jackson
By Greg Kilgore
By Dave D
I have a 2019 coleman 550 outfitter and need help finding out where a wire goes. I put a new starter in and to do that you need to tear half of the inside out! When putting everything back together there’s an extra wire that I can’t find out where it goes. I took pictures of everything before I took it apart and this wire is the only one that blends in with everything around it. Also the new starter doesn’t engage the bendix im assuming it has something to do with the wire?
By amiracle40995
I've never seen the temperature go high on this thing. the fan runs almost all the time even though the sensor is reading at the very bottom of it's range. ive taken the cylinder head off. (nothing definitive but maybe a little fuel on top of piston with oil in it.i don't think this has anything to do with my problem )head gasket is 3 layers deep and I noticed some grit that might have been in between layers but nothing to say the head gasket wasn't intact. black carbon build up on piston. I've looked all over the head for cracks from over heating. I'm about to look again for hairline cracks that are extremely difficult to see. my buddy helping me said to order rings in case they are letting oil pass thru he also said get a new head gasket.. I'm looking at water in oil first and I'm not ordering rings. I haven't checked the oil cooler to see if it's defective yet. I'm just hoping someone had a similar problem. my only problem so far has been having to change the spark plug every 100 miles with 93 octane run thru it.
