so i just started looking at the motor i have in parts and found the piston rod is bent so im looking for a piston rod and crank bearings and ring if anyone has some im intrested and a manual as well, my crank is good and the cylinders are good as well not sure how this happened
the piston is scored but not that bad i think a new set of rings and it will be ok the valves and cam all look good where can i find a shop manual for it so i can see how this motor all goes back together?
Go to  Kawsaki.com, AND go to there Owner center, they should have a PDF of it.
    • By hisun junk
    • By Cory J
    • By SouthernGypsy
    • By se3388
      Steve.............
    • By CYJSP2009
      Dear Joyner owners
      3. Cables,
      4. Brake parts
      5. Engine parts
      6. Other parts.
      Have a good weekend
      Casey /  Leaf Asia
      2023-11-17
