RZR XP® 1000 EPS Trails and Rocks Editionhttps://rzr.polaris.com/en-us/rzr-xp-1000-eps-trails-rocks-edition/
Only if you have an extra $22,500 laying around.....
SPECS
KEY FEATURES
NEW! 55% LOWER LOW GEAR
NEW! XTREME PERFORMANCE AWD
PREMIUM TRAIL/ROCK ACCESSORIES
RZR XP 1000 EPS Trails & Rocks Edition Specifications
SPECIAL EDITION FEATURES
Legendary RZR XP® 1000 Features Plus NEW! 55% lower low gear, NEW! Xtreme performance True On-Demand All Wheel Drive, NEW! Low speed throttle mapping ProArmor crawler XG tires with Beadlocks, High Clearance Front & Rear Suspension, Standard 4,500 lb Polaris Winch, NEW! Gated Shifter, Strengthened Front Half Shafts, Click 6 Harnesses, 14” Ground Clearance, Front Bumper & Rock Sliders, Rear View Mirror & High Visibility Front Fender Flares and more
Power
  • Engine Type
  • ProStar 1000 H.O. 4-Stroke DOHC Twin Cylinder
  • Cylinders Displacement
  • 999cc
  • HP
  • 110 HP
  • Transmission / Final Drive
  • Automatic PVT P-R/N/L/H (Gated Shifter) with Reduced L Gear
Suspension
  • Front Shocks
  • 2 in Walker Evans Needle with 16-Position Adjustable Clickers
  • Front Suspension
  • High Clearance Lower Control Arms, Dual A-Arm with Stabilizer Bar and 16 in (40.6 cm) Travel
  • Rear Shocks
  • 2.5 in Walker Evans Needle with 16-Position Adjustable Clickers
  • Rear Suspension
  • High Clearance Radius Rods, Trailing Arm with Stabilizer Bar and 18 in (45.7 cm) Travel
Agility
  • Drive System Type
  • Xtreme Performance True On-Demand AWD/2WD
  • Front/Rear Brakes
  • 4-Wheel Hydraulic Disc with Dual-Bore Front and Rear Calipers
      Any options on this machine
    • By GunnersTacklebox
    • By Roadstar515
      Regards, Rick
