output shaft change Transmission disassembly how to, any one? Sandviper 1100cc
By Gorj
I am going to replace the batteries in my E1. I am not interested in the high cost Lithium or the expensive 6 volt dry batteries. I am considering four 12 volt deep charge marine batteries. I have a source for 810 amp units for about $100 each. I have no worries about reprograming the charger because it went out a few years ago and I replaced it with generic golf cart charger. When I decide to do this, I'll keep you posted on the results.
By Will D
Hello, I have a mule 4010 trans that appeared to overheat based on the temperature light on the dash and it went into limp mode. No steam though. After letting it cool and the next day, I drove it around quite a bit and it did not have any problems. Any ideas on this. Do thermostats work intermittently? I would like to fix the problem, looking for advice. Many thanksÂ
By ned
I have a Kubota RTV -X900 that I recently got from someone that is in good condition. I'm trying to determine what year it is all to no avail. I have the 16 digit product identification number and have gone on line to multiple sites with no luck. The number is A5KB2FDBCFG024444 . I'd appreciate it if someone could give me an idea where to look this number up and get the year on this unit. Thanks in advance.
By tuell
Hi everyone I have a 2016 hisun vector 550 with 1320 miles on it I recently replaced the clutch the bell the belt the one way bearing basically everything inside the primary and drove approximately one mile my side by side just stopped pulling... no noise no smoke nothing the belt is still good but it's like the transmission will not engage in any gear any help would be greatly appreciated.... I have lifted the rear end and started the side to side put it in gear Wheels do not move but you can turn them by hand
By staind
Looking for information on installing a OBD port or a lite to read codes in ECM.Â
I can not find a OBD port or a lite to read codes on this R2 with 800cc.Â
I have code readers and adapters for most ATV's. From what I've found so far. They don't have a connection for to read codes. I may be wrong. That's why I'm asking.Â
This joyner is the first one I've run across. Well second one in a week. (my neighbors 2 of them) The other was a trooper with the 1100cc chery motor that had been setting for years. After cleaning up the fuse box connections. It runs like a top. Had to replace all gages with aftermarket gages. Water, oil, gas, amp. Only problem one was the water temp using original sending unit. Had to install 150 ohm resistor on the input wire to get it to read correctly + - 5 degrees. Close enough. Gas sending unit was/is for a boat tank 6" tall. All SS so it should last forever.Â
thanks Dan D. aka staind
