    • By Kingfish
    • By hetovi
      Hello everyone.
    • By mac66
    • By sxr951
    • By Jhud
      In the market for side by side. Narrowed it down between the pioneer 1000 or defender Hd9. Looking for pros and cons of both. Any info would be helpful in my selection process. Noise, speed, reliability, ride, all of it.
