Snorkeling a turbo on 09 trooper t2 1100?
01rancher375
No problem at all but make sure every hose on the engine have a clamp on it (vaccum,pcv valve,also make sure the hole where the generator coil wire come out whit the crank sensor wire are siliconed. You will notice probally a 5% engine performance lost due to the snorkel (same story for a car engine snorkeled) but its not a big deal
silverbullet
You can get top performance.Use 2" 3" adapter  2 " side from hose than run 3" PVC to roll cage 90 degree up to top.Hose clamps for roll cage than K&N for trail riding.Uni filter if you run in sand.PVC pipe cut and Glue it.Its very important to do.We rebuild 40 to 50 engines every year from all over the county.We build stock engines and Performance parts.We are experts on Chery engines.And yes we build the 2 cylinder engines.We can get you 85 MPH +
Rich
    • By diamondjfarm
      Thanks.
    • By sxr951
      parts for massimo, hisun,etc in florida? where can i get parts for the massimo 700.. like bolts and console i  didnt see any bolts on amazon to go with cylinders and any thing when rebuilding a 700 engine
    • By Robert Merritt
      I have an older Bristers Trailwagon model TW11 with a Honda engine. I am trying to find a replacement muffler for it. It is an unusual muffler tapped in the center instead of the end with the heat shield welded on to it. Does anyone know where I can find a new one?
    • By Jason S
      Good afternoon,
      I have a 2022 Bobcat 34XL.  Over time, I have to press harder and harder on the brake pedal before the ignition will fire. Now I have to practically stand on it with all my weight to get it to start.  Does anyone know if there is a spring or something that might need replacing, or have had this issue before? I don't have any schematics of the brake sensor/assembly.
      TIA
