Hello all, im new to the board and the utv world. i bought the Joyner a few weeks ago. cost me $600. has Garrett turbo not sure what model. the problems i am having and could use some help on are as follows. a my carb needs to be rebuilt. i can not find a place to just get the gaskets and needles from. any ideas. i am only getting about 90 psi on both cylinders. its a little low. and my fuel pump and regulator. just a mess. i am having trouble finding places to just buy rebuild kits. is there such a place?
silverbullet
The compression is way to low 90 psi will not work.Rebuild the engine and then see what else you need.But first rebuild it parts are no expensive.We carry all engine parts.Plus i know a lot about Joyner Engines.We rebuild 40 to 50 engines a year.All models of Joyners from all over the country.
Thanks Rich
928 344 2117
    • By CYJSP2009
      Dear Joyner owners
      3. Cables,
      4. Brake parts
      5. Engine parts
      6. Other parts.
      Have a good weekend
      Casey /  Leaf Asia
      2023-11-17
    • By Marie
