Hey guys, what winch would you recommend for my Honda Pioneer? And what size? I'm thinking that a 3000 lb rating is good enough. Warn provantage is a popular choice though pricey. How about a Smittybilt winch? What do you think about their ATV winch?
Depending on what you want to do with it, the 3000 lb. winch is probably what you want. For getting a stuck 1200 pound vehicle out of the mud, a 3000 lb. winch is a minimum. But that doesn't mean it'll always be enough to do the job in a worst case scenario. Even with a snatch block, there could be a time there's simply not enough power.
  For logs, it should be enough, especially when used with a snatch block, or 2.
  I find a winch to be a lot of trouble to actually use, and I typically use a come along more often. The winch cable is a pain to get it retracted properly. If it's not done right it'll foul it up in the winding, making it tough to deploy next time. Or worse, it'll damage the cable. You'll want to switch to that soft winch rope as soon as possible, you'll like it better.
  My recommendation is to buy a harbor freight model, or similar, since you won't use it much. Get one with a wireless remote, but make sure there's a wired controller too. Wireless is very handy, but dead batteries can ruin your day. Use a winch cover
   Winching is very dangerous, so read up on proper techniques. ALWAYS leave the motor running! These things can draw a battery down in seconds, at full power.
  Remember, the nearest object to anchor to will always be just out of reach when you're stuck. So take a few extra recovery straps. FWIW, I've got the Warn 3000lb. on mine, and it's about the same size machine.  Hope this helps! Good luck
      Greetings, Can anyone advise the best place to order aftermarket and replacement parts for Articcat ATVs?
    • By gwares
      Price: 4000 EUR
      Everything works and new!
      WhatsApp: +33 758 56 21 59
    • By Greg Kilgore
      I'm 99.9% sure head gasket is blown.
      Don't have coolant in oil. That a good thing. But think coolant is getting in combustion chamber.
      I did compression test.
      Got 120psi walked away. Came back to 105psi 15 minutes later.
      How hard is it to replace?
      https://youtu.be/N31mOtOPuKI?si=nSnuF4-weRU2T10t
      Advise?
    • By Isaac
      I have a 2013 odes dominator when I get in it.  It ideals fine but when you give it gas it bogs and goes and bogs and won’t go passed 30 can anyone help me
