Cylinder Head Bolts
By lmarkie
Any thoughts?
By Greg Kilgore
By mac66
By Ronald
Check engine light comes on after engine runs continuously for 5 minutes or so. I can shut down the engine and restart and check engine light goes out, then comes back on after running 5 minutes or so? What ya think?
By sxr951
