Hello, New member
By Gerald Dillman
By Paul in Wisconsin
I called Cabela's to try and get the saw bar. They said they can't get one and the 800SX doesn't have one!!?? Then why is it listed in the service manual?? No answer from them.
By Gary Odom
By Karlibob
