wheel bearing maintenance
Keyif
Its the yuki cazador 169cc model.2yrs old but not used. just stored.
Also even tho 800km in total I've noticed the front tyres wearing different. the sterring has suddenly become vague. wheels now out of line so going to have to jack it up and reset the geometry.
    • By diamondjfarm
      Thanks.
    • By Ronald
      Check engine light comes on after engine runs continuously for 5 minutes or so.  I can shut down the engine and restart and check engine light goes out, then comes back on after running 5 minutes or so?  What ya think?
      This is the 2020 updated version from the previous 2009 version.  I do not know all the differences.  I do know the 2020 models have throttle body , idle air control valve, & idle control sensor.
      HS700UTV-4/HS500UTV-4 Hisun Axis 500-700 Service Manual
    • By sxr951
      2015 massimo 700.. need cylinder bolt!  it some special cut from factory,, its a 125 thread but its like between 8 and 10 mm  dont know where to find any ideas? thx
    • By Ronald
      I just purchased an Axis Pro 750 from Lowes.  I have two questions not covered in owners manual.  1:  In the glovebox there is a 12V connector, it is HOT with key off, is that for a battery maintainer to be plugged in or what is the purpose?  2:  In the instrument cluster there is a digital read out for hours, miles and odometer,  there is also a digital readout that is flashing, it can be adjusted and looks like 1 - 24  what is it?
