   There will be some exciting, wild, fun for all @ the Imperial Sand Dunes @ Buttercup, Clint Wells, ( Glamis area Oldsmobile hill, the China Wall, these people are of a different breed ! )  etc. starting week before Halloween, ( the weekend will be nuts ) especially @ Glamis, you won't believe your eyes ! then there is     Thanksgiving week, & weekend, be warned, it will be WILD ! for a bit tamer area ( not by much ) Buttercup, Clint wells, and there are areas that you can get away from the crowds plenty of open desert, we like running up Oldsmobile hill, ( Glamis area )    if you never been you are in for a treat ! have fun, & be extra careful
   Go to Glamis sand dunes, scroll down and see videos, of what takes place, 👌
    • By GunnersTacklebox
    • By Fishing Wiskers
      Top speed is 30mph on flat grass ground.  but it will not go up minor hills forward or reverse without a runing start.  If you start at the bottom of the hill machine will stop about 1/2 way up.  I have the engine cover off and you can see the outside of the drive clutch will stop spining., and the engine does bogg down some.  Dosent matter if engine is cold or warmed up.  Seat belts are connected.  Fuel is clean
      I am not sure how to check for codes with this machine,  can anyone teall me how to do it?
      Compression with hot eng is 145,  valves adjusted to .005 with a cold engine.  Dash shows 426 hours
    • By WCF
      Hi Joyner Gang
      New to the Joyner group. I'm making long travel for the 1100 Sand viper. I'm trying to make something that will work as well or even better than the RZR Rino etc. At this time the front has 14" travel rear has 16" of travel. Still developing the suspension. comets are welcome. Ask questions and I will get back to the Forum
