Polaris Primary & Secondary Clutch for 2012-2104 Diesel Ranger 900
By kadams428
Recently my four wheeler has had an issue of being set in gear and it begins riding on its own (up to 3-4MPH). It also is having difficulty shifting into different gears after riding in one gear (i.e. going from reverse to high gear). It will shift perfectly fine when shut off, but consistently has both issues stated above.
Previous research has shown me that it could be an issue with belt tension/deflection, however I have been unable to figure out how to do that with these machines. I've seen some clutches have a jam nut and all that is needed is a wrench and an Allen key to make adjustments, but I haven't seen/found that on the 600 clutches. Has anyone done this in the past or have knowledge of how to accomplish this?
By mac66
By 4x4friend
I have a 2012 Hisun ut400 that I just bought. I was told it just needed a belt, but nope, all three clutches were shot. So I went online and found a couple videos on replacing the clutches. They stated that the wet clutch and primary clutch should turn easily counterclockwise and harder clockwise because it's turning the engine over. So that is what I'm getting when the wet clutch housing bolts are loose, when I tighten them the shaft now turns very hard counterclockwise. Anyone have any ideas as to the problem?
By sxr951
By Kalyla Jackson
🗓️ **Dates:** August 6 - August 25
💥 **Discounts:** Up to 20% OFF
🎁 **Special Offers:** Receive free gifts with purchases over $169 (including keychains, whip lights, speakers, and more!)
Gear up for your fall ride with top-notch UTV/ATV accessories. Don't miss out!
🔗 Shop Now: https://kemimoto.sjv.io/Vmq9VJ
