acv diaphram
By SouthernGypsy
By Jon V
Good afternoon. When the timing chain came off its lower gear (previous owner had over-tightened the tensioner), I ordered new parts.. chain, oil-pump chain, tensioner etc.. But now that it's time to put it back together, the main crankshaft makes a clang noise and stops when you turn it by hand. I want to solve this before assembling everything. The camshaft cover is off so that the valves aren't being activated. Should the transmission be in neutral to turn the crankshaft? The engine was running fine until the chain came off the lower gear. Then it would spin when the starter motor engaged so I assumed the crankshaft was spinning. Any advice is appreciated.
By GWS
I am looking for the part numbers for the primary and safety air filters that will fit a 2020 Tracker 800SX
By mac66
